I'm trying to overclock my old AMD system. I'm going for the fastest stable overclock with an even hundred digit clock speed in MHz (3200MHz, 3400MHz, 3600MHz, etc.), ideally above 3.5GHz, I've seem to hit a ceiling at ~3.4GHz. It will boot fine at 1.35V, but fail Prime95 (in place FFT) inside of 30 minutes. Temps don't exceed 35c.
Here are my system specs:
AMD Athlon II x4 630 CPU (C2 Stepping)
Zalman CNPS 9900A-LED
ASUS M4A785-m Motherboard
2x 2GB Kingston HyperX DDR2-1066
Integrated Radeon 4200 (500MHz)
750GB Seagate Barracuda
Rosewill 530w Green series (80+ cert.)
Windows 7 Home Premium x64
Here are my OC settings so far:
CPU
Mult: 12.5
Bus: 267MHz
Voltage: 1.35 - 1.375V
Freq: 3338MHz
--other--
CPU/NB Freq: Auto
VDDNB Volt: Auto
LoadLine Cal.: Auto
RAM:
DRAM: 400MHz
Voltage: 2.205V
CAS: 5-5-5-15
Timing Mode: DCT 0
Freq: 1068MHz
HTT:
Mult: 8x (1600MHz)
Width: 16bit
Volt: 1.205V (<-- lowest setting)
Freq: 2136MHz
Something to note: adding voltage passed 1.3625V seemed to adversely effect stability. At 1.38125V, Core #3 failed inside of 2 minutes, which is strange because Core #2, and #4, seemed to be the unstable ones with both failing simultaneously at 15, 10, and 7 minutes at 1.3625, 1.36875, and 1.375V respectively. I've done a pass of Memtest86 with no error at current memory settings (1068Mhz).
Are there any changes you would suggest, or just admit I have a not-so-great OCing chip and call it quits?
CPU
Mult: 12.5
Bus: 267MHz
Freq: 3338MHz
--other--
CPU/NB Freq: Auto
VDDNB Volt: Auto
LoadLine Cal.: Auto
RAM:
DRAM: 400MHz
Voltage: 2.205V
CAS: 5-5-5-15
Timing Mode: DCT 0
Freq: 1068MHz
HTT:
Mult: 8x (1600MHz)
Width: 16bit
Freq: 2136MHz
