~$1,400 i5 Gaming Computer ~final parts list~
Hello. I discovered Tom's Hardware about a month ago when I started getting interested in building a gaming computer.
I really only had two goals initially:
1) Can play World of Warcraft on the highest settings.
2) Has fairly high quality parts and will last a few years.
But I'm pretty sure this machine will be able to do much more.
- - - TEMPLATE - - - - - - - - - - - - - - - - - - - - - - - - -
APPROXIMATE PURCHASE DATE:
(already ordered)
BUDGET RANGE:
(~$1,400)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT:
(---GAMING---, using Photoshop, watching movies, internet)
PARTS NOT REQUIRED:
OS (I have already purchased Windows XP Pro)
PREFERRED WEBSITE(S) FOR PARTS:
(ordering from some Japanese sites)
COUNTRY OF ORIGIN:
(U.S.)
PARTS PREFERENCES:
* Intel core i5 750 CPU
* 24 inch monitor
OVERCLOCKING:
(yes)
SLI OR CROSSFIRE:
(no)
MONITOR RESOLUTION:
(as high as possible within price range)
ADDITIONAL COMMENTS:
(Will be using an external DVD burner instead of internal because I need to use the DVD burner on other computers too)
The following is my list of parts. (links are mostly to Newegg, but I'm actually ordering from other sites. The prices are the prices I'm paying.)
---------- CASE ----------
Antec Nine Hundred
$135
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&cm_re=antec_nine_hundred-_-11-129-021-_-Product
---------- CPU ----------
Intel Core i5-750 (Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W)
$212
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215&cm_re=core_i5_750-_-19-115-215-_-Product
---------- CPU COOLER ----------
CoolerMaster Hyper 212 Plus
$38
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=hyper%20212%20plus
---------- THERMAL COMPOUND ----------
Arctic Silver 5 Thermal Compound
$14
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007&cm_re=arctic_silver_5-_-35-100-007-_-Product
---------- MOBO ----------
ASUS P7P55D-E
$180
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131620&cm_re=P7P55D-E-_-13-131-620-_-Product
---------- RAM ----------
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
$147
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260&Tpk=CMX4GX3M2A1600C9
---------- HDD ----------
Samsung Spinpoint F3 1TB SATA (HD103SJ / 7200 RPM 32MB Cache 3.0Gb/s 3.5)
$73
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=HD103SJ
---------- SCRN ----------
LG W2453V-PF Black 24" 2ms(GTG) HDMI Full HD 1080P Widescreen LCD Monitor 300 cd/m2 50000:1
$206
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005126&cm_re=W2453V-PF-_-24-005-126-_-Product
---------- PSU ----------
Antec EarthWatts EA-650 (650W ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified)
$98
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015&cm_re=EA-650-_-17-371-015-_-Product
---------- GPU ----------
Sapphire HD5770 1G GDDR5 PCI-E DUAL DVI-I/HDMI/DP
$195
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858&cm_re=HD5770-_-14-102-858-_-Product
---------- DVD DRIVE ----------
Sony Optiarc Black AD-7240S
$32
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030&cm_re=sony_optiarc-_-27-118-030-_-Product
---------- DVD DRIVE ENCLOSURE ----------
Scythe 5.25 inch enclosure KMZ2-5SATA-BK
$29
http://www.scythe.co.jp/accessories/kamazo2-525sata.html
---------- MOUSE PAD ----------
SteelSeries QcK Mouse Pad (Black)
$10
http://www.amazon.com/gp/product/B000UYANGM/ref=oss_product
---------- KEYBOARD ----------
Saitek Eclipse Keyboard
$38
http://www.newegg.com/Product/Product.aspx?Item=N82E16823175103&cm_re=Saitek_Eclipse-_-23-175-103-_-Product
---------- MOUSE ----------
Logitech MX 518 High Performance Optical Gaming Mouse (Metal)
$43
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178&Tpk=Logitech%20MX%20518
$135 - CASE
$212 - CPU
$38 - CPU COOLER
$14 - THERMAL COMPOUND
$180 - MOBO
$147 - RAM
$73 - HDD
$206 - MONITOR
$98 - PSU
$195 - GPU
$32 - DVD DRIVE
$29 - DVD DRIVE ENCLOSURE
$10 - MOUSE PAD
$38 - KEYBOARD
$43 - MOUSE
----- TOTAL PRICE -----
$1,450
Everything is ordered and will begin building it next week. Hopefully it won't explode when I turn it on. Let me know what you think. =)
Thanks for taking a look.
-Eggers
7 answers Last reply
More about gaming computer final parts list
  1. 1) not bad for a beginner, but you can do better.
    2) where's the dvd drive?
    3) nope, you don't get it. WoW doesn't care about gpu/cpu. I'm not saying you run it on IGP, but you NEED a fricking fast Internet connection or you'll lag bad or you get killed major. Research what ISP most WoW users use in Japan and GET THAT! (ask around in forums; not this one) Dumb down your specs like PSU = overkill = waste of money. You can get a respectable AM3 dualie at 3Ghz and a AMD 770 mobo. You seem to be in the wrong group where gamers like the look of their pcs more than what's on the screen. Which is more important, ask yourself?
    4) They're the same. 8.0 means 7.1 strictly = 7 speakers + 1 subwoofer in the correct location like surrounding you. If you're wearing a headset or headphones, audio won't matter 1 bit. You'll be using stereo all the time.
    5) not bad. Samsung is very popular in the west.
    6) None.
    7) i5 750 has turbo mode. All you do is turn on turbo in bios on the mobo and you're done. It'll auto overclock to up to 3.2ghz, depending on things like heat.
    I already have the DVD drive.
    Thank you very much for the reply, p55ibexpeak !!! I've edited my original message to reflect the answers you gave me.
    I'll look into the available ISPs here for sure. :)
    And I'm glad there is no difference between the two GTS 250s I listed. I'll go with the cheaper one.
    Great information. I really appreciate the advice. :D
  3. Thank you again p55ibexpeak. I have decided to go with that mobo you listed since it has the USB 3 and SATA 3 support.
    I also updated the original post to reflect that and other changes / additions.
    I just have a couple more questions:
    1) The current build I have listed above is $191 over budget. Where should I scale back to get it back to the $1,100 mark? Or is it worth it to just bite the bullet and spend the extra money for a machine that will last longer?
    2) The reason I'm looking at that Arctic Cooling CPU cooler is that I'd like to try to overclock the processor by putting it in turbo mode through the BIOS and I'm worried that the stock CPU fan/heatsink is not good enough. Is that CPU cooler worth it or should I just stick with the stock one?
    Thanks!
    -Eggers
  4. 1) Like I said in my previous post, you can and should go with AMD due to your budget. You won't back down from the expensive case & psu.
    2) The AC cooler is kinda old. You might get this for less. It's not bad.
    Thank you very much for all your advice p55ibexpeak. It helped me a lot in looking at my options.
    After taking everything into consideration, and also realizing that I need a good keyboard and mouse, I've decided to raise my budget to $1,400, and I've compiled a final list of parts at the top of this thread. All comments welcome. Have not ordered yet. I'd like to get some opinions on the build before I place the order. Thanks.
    -Eggers
  6. FINAL BUILD updated in the OP. Everything is ordered. Will build next week.
    -Eggers
New Build Gaming Systems Product
