Help with new build!!!
eddale01
23
I am on a budget around $800-$850
I plan on ordering this weekend!
I only play one game(heroes of newerth), and a ton of photoshopping(wife is photographer)
I am very open to overclocking, I am very fascinated with it and want this to be a hobby.
I have plenty of HD space on externals.
I WANT FAST on a BUDGET!!
I have done a ton of research and this is what i have setup.
Phenom II x3 720 - plan to overclock to max potential!
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103652
MSI 770-G45 AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130250
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
2 - OCZ Solid 2 series 60gb SSDs in RAID 0
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227475
OCZ MdXstream Pro 600W PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
Sony Optaric CD Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
A $15 media card ready all in NZXT M59
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
The case, it is cool looking and it has built in SSD adapter that houses 2 SSDs
I will grab a Corsair H50 water cooler for the cpu - it is on sale at best buy for $59.
I have an Asus radeon HD 4650
All of this comes out to $810 after shipping and mail-in-rebates including the water cooler.
I am very open to changes as long as the price does not change to much, also recommendations to graphic cards! on a budget of course.
The SSDs will likely be bottlenecked by the lack of SATA III ports on your motherboard, and when you use SSDs they like to have empty space (generally up to half full is a good amount). This means that effectively you will only have 60GB for OS, programs, and some storage. Another thing to think of is that external devices will take longer to transfer data to. Personally I would choose the F3s in raid 0.
eddale01
23
That is what the SSDs are for, the OS and a little bit of data. I was also wondering whether the SSDs are worth it, or should I go for something like 2 of the Samsung F3 1TB in raid 0. I do not care about the little space for the money if the performance in the SSDs is worth it.
mavanhel
445
eddale01
23
Like I said above.. I have plenty of external space... Every time my wife finishes a photo session on photoshop she puts everything on to an external anyways.. i do not know whether the mass storage is important because i have 2tb external
