Solved
What power supply will work w/ overclocking?
hi, this is my first build ever and im building a new comp from newegg and im thinking of using:
CPU - AMD Athlon II X4 620 Propus 2.6GHz Socket AM3 95W
Motherboard - ASUS M4A77D AM3/AM2 /AM2 AMD 770 ATX AMD
Video Card - XFX HD-487A-ZWFC Radeon HD 4870 1GB
Fans - 4x120mm fans
HS&Fan - COOLER MASTER RR-H101-22FK-RA 80mm
Ram - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
Tower - APEX Vortex 3620 SGCC / ABS ATX Mid Tower
thanks in advance if you have any ideas, preferably a power supply from newegg...
6 answers Last reply Best Answer
More about what power supply work overclocking
  1. This will be a good PSU for that setup and room to OC http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
  2. if you dont mind me asking but is that the bare min? im sorry but i dont understand the psu at all im not sure what to look for etc... sorry if im being a pain
  3. i mean im just on a tight buget thas all... but if you think that will last me then i just need the word i guess...
  4. Best answer
    The PSU feeds power to your PC and a cheep PSU can lead to a unstable system or fried components, seeing you want to OC and all not really a part to go cheep on.
    This ones 10 bucks less and also has a MIR http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
    the corsairs only 60 bucks after the MIR not a bad deal ( I have got all my MIR back from Corsair )
    Maybe others have some input
  5. gotcha, thanks alot! this whole power supply thing had me really nervous, without you im sure i would have fried up my comp :)
    if others have input im all ears!
  6. Best answer selected by cruestix142.
New Build Systems Product
