Not sure if this is the best subforum or not, but here goes.
Just assembled a new build with i5-3570k, CM Hyper 212 evo, asrock Ex4, Muskin 1600 2x4GB, SSD boot drive, 550W psu, DVD burner. I have not installed the HDD yet and have not purchased a gpu yet, it is running on the HD4000. Got windows 7 64 bit installed. Customized windows using the recommendations found here <http://www.overclock.net/t/1156654/seans-windows-7-install-optimization-guide-for-ssds-hdds>.
No problems until I installed Titans Quest. Played a few hours last night no issues. Played 30 mins tonight and BSOD. Tried again, made it 45 mins and BSOD. Installed C&C RA3 and had 2 BSOD both attempts at the opening cinamatic. The BSOD read memory management.
Booted to Memtest86. No errors on 3 passes.
Been running Prime95 for 20 mins. Max temps between 54-58 deg C. (Nothing is overclocked yet)
Any advice on where I might have messed things up. Both of these games are years old and not the most taxing. Prime95 is not causing thermal shutdowns and memtest86 is showing no errors.
Did I mess a setting up from that go-by I used to optimize windows for my SSD?
Any help would be greatly appreciated.
