Hey,
I'm trying to get my old Dell up and running again, but I'm getting the STOP: 0x0...025 BSoD whenever Windows starts to load. From what I've read this is most likely due to my hard drive being corrupted somehow. Running chkdsk /f (or /r?) should be able to clean it up and get me back into windows. I'm using my Windows 7 boot disk to use the repair tools (the computer currently has xp installed but I lost the boot disk). In command prompt I tried running chkdsk but it keeps returning the message "cannot continue disk checking because volume is write protected." So then I tried DISKPART detail volume and got:
Disk 0 Online 74GB 6144KB
Read-only: No
Hidden: No
No Default Drive Letter: No
Shadow Copy: No
Offline: No
Bitlocker Encrypted: No
Installable: Yes
Volume Capacity: 69 GB
Volume Free Space: 24 GB
It also has a status of healthy when i list volumes. From what this says, it is not write protected. I used the command "attributes volume clear readonly" just to see if that helps but it still says its write protected when I try chkdsk. I don't know much about using command prompt and all the different commands so I was hoping some one here might have an idea.
Read-only: No
Hidden: No
Shadow Copy: No
Offline: No
Installable: Yes
