Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Armada M700 - Wont start up on battery power only?!?
Forum Laptops & Notebooks : General Laptops & Notebooks - Armada M700 - Wont start up on battery power only?!?
Archived from groups: comp.sys.laptops (More info?)
Hi,
I brought a second hand Armada M700. Anyway I plugged the AC adaptor in and
started charging the battery, whilst this was happening I installed windows
XP Pro onto it. Anyway after everything had installed I switched it off and
left it to charge until the charging light went out.
After it did I unplugged the AC adaptor and tried to turn it on but nothing,
it wont start using the power button.
Now am I doing something wrong here? It will start fine with the AC adaptor
in using the power button but wont work on just its battery. Thing is
battery reports 100% charge in windows and the green LEDs built into the
battery also report full charge?!!??!
Anyone any idea ?
I've tried compaqs battery test but it doesnt seem to work under XP
Cheers
ben J
Sponsored Links
Benje wrote:
> Hi,
I had the same problem with my old M700. It's been a while since I sold
it, so I can't remember if the battery was reporting a charge while on
AC in Windows, but the rest of the symptoms were identical. The laptop
would work on AC, battery would charge, but unplug the AC and the laptop
would just die.
It turned out the battery was faulty. Compaq had a recall on M700
batteries, and they replaced mine (the laptop was still under warranty).
Give them a call, you may be lucky and they'll replace it. Otherwise you
need a new battery.
Cosmin
Reply to Anonymous
There are 1361 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
