Cooler to replace Arctic Cooling Freezer 7
like the title says i am looking to replace my Arctic Cooling Freezer 7 rev2. i had the original Freezer 7 in my last build and it was very quiet, even when it ramped up speed. this new one quite a bit noisier though. at idle is has a slight tick and whenever i start up a game or prime95 it ramps up and sounds like a plane taking off.
it cools just fine; the 2500K is oc'd to 4.0Ghz, for now, and temps only hit 45C after 8hrs of prime95.
i was thinking of getting a Hyper 212 EVO because i heard they are quiet, but the Freezer 7 is also "supposed" to be quiet. if anyone can recommend a different cooler, or has experience with both these coolers, i would like some advice on finding one that is actually quiet and cools well. i know i am posting this in the air cooling section but a closed loop water solution is not off the table.
my system:
i5 2500K@4.0Ghz
Asus P8Z68-M PRO(micro ATX)
Antec 300 case
my budget: $80 for air $120 for water US Dollars
3 answers Last reply
More about cooler replace arctic cooling freezer
    my system:
    i5 2500K@4.0Ghz
    Antec 300 case
    Try Thermalright True Spirit or HR-02 macho both are "Unbeatable performance and quiet!"
    Available at Amazon.
  2. CPU Cooler:COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Heatsinks Cooling Arctic Overclocking Product
