Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
Item #: N82E16827118030
Return Policy: Limited Replacement Only Return Policy
Protect Your Investment (expand for options)
Service Net Replacement Extended Warranty Plan
The product will be replaced and shipped directly to you at no charge(more info)
• 1 year: $6.99
• 2 year: $11.99
$24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
BELKIN F5D7010 Wireless G Notebook Card - Retail
Item #: N82E16833314306
Return Policy: Standard Return Policy
-$20.00 Instant
-$9.99 Saving
$29.99
$0.00
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case - Retail
Item #: N82E16811119197
-$20.00 Instant
$109.98
$89.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152185
$89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... - Retail
Item #: N82E16817139006
-$10.00 Instant
$10.00 Mail-in Rebate Card
$139.99
$129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
G.SKILL ECO Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBECO - Retail
Item #: N82E16820231321
Return Policy: Memory Standard Return Policy
$119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
Item #: N82E16813131621
$189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
• SAPPHIRE 100281SR Radeon HD 5870 (Cypress XT) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video ... - Retail
Item #: N82E16814102856
Return Policy: VGA Replacement Only Return Policy
o 1 year: $39.99
o 2 year: $79.99
• Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Item #: N82E16832116754
Return Policy: Software Return Policy
-$20.00 Combo
$514.98
$494.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.298042
• Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail
Item #: N82E16819115215
Return Policy: CPU Replacement Only Return Policy
• COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long ... - Retail
Item #: N82E16835103065
-$8.00 Combo
$229.98
$221.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.296096
-$20.00 Instant
-$9.99 Saving
$29.99
$0.00
Subtotal: $1,361.89
With this system you can add other HD 5870 down the road if you like it has usb 3.0 and will give grate FPS in games and you could OC the CPU if you like
Anyways its your money your call, but i would not pay that kind of money for a dead socket
