Solved
New system build @ $750-850.
Last response: in Systems
APPROXIMATE PURCHASE DATE: August 2010 or later
BUDGET RANGE: $750-$850
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming specifically wow, hon
PARTS NOT REQUIRED: mouse monitor speakers, only need tower and its parts. (have a 9800 GT GPU if there isnt enough for another gpu)
PREFERRED WEBSITE(S) FOR PARTS: preferably anything for nsw/paramatta pickup
COUNTRY OF ORIGIN: AUS
PARTS PREFERENCES: this thing must be able to have wow perform on 100% all maxed settings so what it takes to achieve that
OVERCLOCKING: dont know the first thing about it
MONITOR RESOLUTION: 1440x900
ADDITIONAL COMMENTS: decent lookin case if it can fit the budget
More about : system build 750 850
Best solution
The skycomp place doesn't sell the i3 530 which is why the i5 750 is there. A Graphics card is not included
i5 750 258 http://www.skycomp.com.au/product.aspx?id=190645
ASUS P7P55-M 150 http://www.skycomp.com.au/product.aspx?id=197415
Corsair TW3X4G1600C9D 4GB 171 http://www.skycomp.com.au/product.aspx?id=186329
Antec 300 92 http://www.skycomp.com.au/product.aspx?id=100162
Corsair VX-550 109 http://www.skycomp.com.au/product.aspx?id=91883
COOLER MASTER HYPER 212+ 37 http://www.skycomp.com.au/product.aspx?id=202169
SEAGATE 1TB 149 http://www.skycomp.com.au/product.aspx?id=190431
Total: 966
Way out of your budget.
i5 750 243 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
SEAGATE 1TB 103 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
Corsair TW3X4G1600C9D 4GB 162 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
ASUS P7P55-M 129 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
Corsair VX-550 107 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
Antec 300 82 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
COOLER MASTER HYPER 212+ 48 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
Total: 874
Just in your budget although once you add postage it won't be, my guess is max $50 postage. This place allows you to pick up if you are near Brisbane anytime soon.
If you get a i3 530 with the gocomp purchase then the price will be:
i3 530 167 http://gocomp.com.au/index.php?cpath=productinfo&pid=II...
Total: 789
If you add $50 postage this will still be in your budget.
To others if you have suggestions please post.
thanks very much for all suggestions, going by the_punkinators second list with a cheaper hard drive and getting some of the parts from cheaper shops i can cut it down to about 750 with the i5. Only thing i am concerned about is that is it worth reusing my 9800 GT for a graphics card, is it capable of max wow settings?
Ask the community
