Solved
Sound card solutions
Last response: in Components
April 6, 2010 8:58:45 AM
I am looking for a sound card that has a front panel headphone output. So far, all I can see is something like the Creative x-fi fatality champion series.
I'd also appreciate comment on headphones as well. I've been looking at the Sennheiser units, but they seem a bit bulky.
More about : sound card solutions
Best solution
April 6, 2010 4:22:24 PM
Something like the ASUS Xonar DS 7.1 can hook up to the front panel jacks on your case if it has them. But if your case doesnt have them then the X-FI Fata1ty is the way to go.
Another way is if you dont have the audio jacks on your case already you can get one of these.
Multi Port Panel for Front Drive Bay
April 6, 2010 10:22:53 PM
Best answer selected by croc.
m
l
