thin & light recommendation?
Forum Laptops & Notebooks : General Laptops & Notebooks - thin & light recommendation?
Archived from groups: comp.sys.laptops (More info?)
Hi,
It looks like my Averatec 3150H will always be plagued by thermal issues,
and I need to replace it.
What do people recommend for thin and light laptops? My basic requirements
are:
* No more than about 4.5lbs and 1.4" thickness when closed.
* Must have built-in optical drive
* Small screen is actually preferred, I like the 12.1" on the Averatec
* Built-in ethernet and (hopefully) wireless
Not too picky about CPU speed, and as long as I can at least upgrade to
512MB or more RAM, I'll be happy.
So other than Averatec, what do people recommend?
thanks,
Jonathan
Sponsored Links
On Fri, 6 Aug 2004 15:02:26 -0400, "Jonathan"
>are:
IBM ThinkPad T40/41/42 would mostly fit the bill.
It's 4.9 lbs (2.22 kg) with optical drive (which is removable) and
1.0-1.2" (26.6-31.4 mm) thick.
There's one. You can also put a range of accessories in the Ultrabay
Slim: 2nd HDD, 2nd battery etc.
Display size is actually 14.1". If you want 12.1", consider the X40
(2.7 lbs / 0.81-1.06" ) or the X31 (3.6 lbs / 0.98-1.19" ). I'd
personally prefer the X31, because of it features a standard 2.5" HDD
(the X40 has an 1.8" HDD). In fact, I'm the happy owner of an X31 ;-)
Goes without saying. Some models even have gigabit Ethernet and
802.11a/b/g wireless (and Bluetooth too).
Will max out to 2 GB (T4x & X31) or 1.5 GB (X40). They all feature a
Pentium M (= low heat, low noise, long battery life).
Never heard about Averatec, but I only have good things to say about
IBM (satisfied user of their laptops since 1996).
Cheers, Dominique
Reply to Anonymous
Take a look at Portable 1's new offering the UX. Basically a sup'ed up Asus
M5N. It has everything you want.
http://www.laptopsinc.com/Merchant [...] _Code=P1UX
Reply to Anonymous
"JCBlueEyes" <jcblueeyes@aol.com> wrote in message
news:20040808151002.12055.00003440@mb-m01.aol.com...
Does the pointing pad of the UX have scroll function?
Reply to Anonymous
Hmmm, I've never heard of Portable One before. One of my big concerns is
reliability, as I've recently been burned by buying a cheaper brand to save
some dough. How does the UX hold up? Are there any long-term reviews of
it? On the surface, it sure does look like a nice machine though.
thanks,
Jonathan
Asus
Reply to Jonathan
"Jonathan" <jonathan@sprintmail.com> wrote in message
news:SKGdnd2J5eo4SovcRVn-vg@speakeasy.net...
> thanks,
> Jonathan
What exactly is the problem with Averatec? I was looking at the Averatec 3220HS.
Adam
Reply to Anonymous
I have an Averatec 3150H that I bought Oct. '03.
Basically, it's a great little laptop with one big design flaw: lack of
good cooling.
You cannot run this laptop at full CPU utilization for extended periods
because it cannot keep itself cool. As such, over time, it develops
numerous thermal failures. I know this because I run the United Devices'
grid computing agent, doing cancer research. Any grid computing tool that
utilizes "unused" CPU cycles is likely to do the same thing. If you don't
run United Devices, SETI@home or the like, then you're probably OK. However
the design flaws are present, even if they aren't causing you problems. My
3150 has had repeated CPU failures, a RAM failure, and I've begun getting
S.M.A.R.T. warnings on the hard drive.
The 3220 series are close cousins of the 3150, so I'd expect to find the
same problems there. I'm not saying don't buy it, but I am trying to set
your expectations based on my experiences. It's really hard to resist
Averatec, given how much they give you for your dollar.
good luck,
Jonathan
"Adam Helberg" <sendspamhere@yahoo.com> wrote in message
news:fgBRc.14106$9Y6.504@newsread1.news.pas.earthlink.net...
is
save
of
> > thanks,
> > Jonathan
3220HS.
> Adam
Reply to Jonathan
news:poSdnakzr_TO6IrcRVn-sQ@speakeasy.net...
> good cooling.
> good luck,
> Jonathan
> is
> save
> of
> > > thanks,
> > > Jonathan
When you get a replacement (Portable One UX?) can you post a review. I'm looking for
something similar.
Adam
Reply to Anonymous
See all of the choices listed at www.conics.net and www.dynamism.com
You've got with optical drive:
Sony TR-series
Panasonic W & Y-series
Fujitsu T70H-series, P7000 series
Sony S-series
JVC Interlink XV series
Cheap, I'd go with the Averatec 4lbs sold at Staples for $699 on sale
now and then.
Otherwise, I'd go with the Fujitsu T70H series -- built-in DVD burner,
longer battery life than the comprable Sony TR series in size & weight,
big 80GB HD, and does just about everything in a compact 3lbs.
Reply to Anonymous
> good cooling.
> good luck,
> Jonathan
When you don't run the grid computing software and use it for "normal" computing
(word processing, internet access, educational software) does it still have the
thermal problems?
Adam
Reply to Anonymous
"David Chien" <chiendh@uci.edu> wrote in message
news:cf8t3g$4e5$1@news.service.uci.edu...
> Sony TR-series
> Sony S-series
> now and then.
Unfortunately the Sonys and Fujitsu are wide-small screens for watching personal
DVDs. Some programs do not display well on the wide screen.
Reply to Anonymous
news:fuWRc.15327$cK.9263@newsread2.news.pas.earthlink.net...
> > good cooling.
Devices'
that
don't
However
My
getting
set
> > good luck,
> > Jonathan
computing
have the
> thermal problems?
No, it seems to be fine then. So it makes sense not to run such
applications. If you just use normal office type apps. you should be fine.
However, I contend that poor design of the laptop shouldn't cause me to have
to constantly be aware of what apps. I'm running and how much they're
stressing the CPU. Maybe I'm just asking too much from a $800 notebook.
FWIW, I could never get any environmental monitors to work with this laptop
(I like MBM5 normally), but such a tool would be really nice to have so you
could see the CPU temp. and other indicators of stress and/or overheating.
-Jonathan
Reply to Jonathan
Fujitsu P Series.
dk
news:EaCdneSBc4bnSI7cRVn-vg@speakeasy.net...
> Hi,
requirements
> are:
> thanks,
> Jonathan
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > thin & light recommendation?
There are 572 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
