Poor color on new monitor
i purchased a new monitor and the copor is very poor, my old one had great color. It says iI need 1366 by 768 resolution but I only have 1360 by 768 is this the problem? Thans for any help.
2 answers Last reply
More about poor color monitor
  1. that's close enough most likely. you can play with your color settings using the monitor's menu options i would think. also can adjust your color using your graphics card, nvidia or ati etc. you should be more specific when asking a question, what kind of monitor, computer, operating system etc to get better help :D
  2. We need more info about your problem here...
    What do u mean by "poor"?
    What are the system spec? Monitor? Resolution? GPU card?
    Did u install the driver for graphic card?
Graphics Cards Resolution Monitors Graphics
