Hi,
Apologies, this will be a bit long winded but any help would be fantastic!
(The Background)
Basically, last year April-ish, I posted on here asking for some help with this graphics card. Here is a quick reminder:
"Intel Core 2 Quad Q6600 @ 2400 MHz
Physical Memory: 3072 MB
Video Card: Nvidea GeForce 9600 GS
Hard Drive: 750GB
Power: Corsair 650w
About 2 or 3 games have had the same problem where, after 20-30 minutes, my whole PC crashes with only the sound looping in the background. Weird thing is, there is no consistency. For example, i was able to run Crysis without crashing once but a game like Assassin's creed, i can not play for more than 15 minutes."
Someone on this board kindly explained that it could be the "black screen of death" 9600GT (Mine being GS, might not matter) was well known to cause problems for people. I went through all the fixes at the time and being skint, I couldn't invest in a new graphics card.
(Currently)
Well now, I have about £90 (Maybe £100 at a push) to spend on a new graphics card and I'm looking for a suitable replacement which is equal, if not better to what I have at the moment.
First things first however, I'd like to make 100 % sure that the graphics card was causing all this problems, so I decided to try my brothers 8600GS. Only thing is, I'm having problems removing a wire which is connected from my graphics card to the motherboard. I'm not sure what it is and how to remove it without damaging it.
Here's couple of pictures of this wire, sorry about the picture quality:
http://img641.imageshack.us/img641/4619/dsc00123.jpg
http://img27.imageshack.us/img27/3931/dsc00122i.jpg
I will discuss about graphics card choices after I test it .
Thanks for your help
(The Background)
Hard Drive: 750GB
Power: Corsair 650w
(Currently)
