MSI G31M overclock.. help?
Hello, I have recently gotten a new computer case for my computer(Zalman Z9plus) and feel pretty confident about over clocking my cpu. I was just wondering how to do so.
My computer Specs are:
windows 7
Pentium Dual-Core E5500 @2.80GHz
4096 GB ram
AMD Radeon HD 6700 1GB
I was just wondering if I could over clock it to 3GHz or maybe even a tad higher, but would like a little bit of help on doing so. thanks! :)
4 answers Last reply
More about g31m overclock help
  1. You should be able to get 3.6Ghz. But you need decent aftermarket cpu cooler like hyper 212+
    Follow this thread. I overclock my 5400cpu with same as yours.
    http://www.tomshardware.com/forum/forum2.php?config=tomshardwareus.inc&cat=29&post=267735&page=1&p=1&sondage=0&owntopic=1&trash=0&trash_post=0&print=0&numreponse=0&quote_only=0&new=0&nojs=0
    You will be fine.
  2. Thing is though, no matter how much I change the CPU FSB speed, it still shows as 2.8GHZ in CPUID, and in windows. maybe point out my error using these pictures?
    thanks! (BOIS is AMI American Megatrends v7.4)
  3. This topic has been moved from the section Motherboards & Memory to section Overclocking by The_Prophecy
  4. okay, I'll just take that I can't overclock with this old computer? :(
CPUs Overclocking Computer
