I just built a computer for my parents, not an expert, but not a newbie either.
I have an ASUS P6X58D Premium motherboard and 12GB of Corsair 1333 (6 x 2gb) TR3X6G1333C9
After finishing everything up I hit the power button and all the fans started to spin, but my motherboard's DRAM LED turned Red.
According to the manual this means that that either the DIMM is not properly installed, or not compatible. So I first tried reseating all 6 sticks, and got the same error. Nothing appears on the monitor, no signal.
So I tried the MemOK! feature of my motherboard, thinking that maybe my memory isn't compatible. That was unsuccessful as the button didnt do anything, the light didnt blink etc.
Also, the power button / reset button on the front panel didn't work once I started the computer. I had to power off by turning off the switch on the power supply. Also the power/reset on the Mobo itself doesn't work either once the computer is on.
This is my first problem ever with computer hardware and I'm really not sure where to start. Any idea as to whether its bad DIMM, not compatible, bad Mobo...? My parents have been waiting for this computer for a long time, argh, such a setback
Thanks for any help you can give!
