Overheating problem in amd
Hello,
I bought AMD fx 8150 Bulldozer processor....not only it gets overheated but crashes very frequently even if I run simple programs.
I am using it on Sabertooth 990FX R 2.0 Motherboard and 32 bit windows 7.
The present situation is like hell, I cannot even do simple jobs on my PC.
Please help me or tell me what the remedy is from your side (its in warranty period)or make the suitable changes in hardware.
Earliest possible help is sought.
6 answers Last reply
More about overheating problem
  1. drsudhirkgupta said:
    Hello,
    Check temps with Core Temp should be 35C or below on idle and below 60C while stress testing on prime 95 also make sure the sabertooth is not overclocking it.
  2. Sounds to me like the heatsink isn't mounted correctly, or a job at overclocking was horribly botched with too high Vcore.
    We can't tell you how to make suitable changes in your hardware if you don't tell us what hardware you have...
  3. How long before it overheats? What CPU cooler are you using? I assume you didn't overclock? I'd bet the CPU cooler just isn't seated right or you didn't put thermal paste on it when installed.
    Lastly why did you pay $100 for windows 7 and only get 32 bit when for the same price you can get 64bit which is better in ever way but the size of the install on your HDD.
    Yeah he needs to make sure the CPU is running on the right voltage and that the Heat-sink is mounted on right
  5. Are you sure it's your CPU?, i think it could be something like bad ram too or am i wrong?
  6. drsudhirkgupta said:
    Hello,
    Use HWmonitor to see what is overheating it could be bad ram as said above, often the cpu will crash on boot or start up.
    check for other culprits.
AMD Overclocking
