Graphic card: XFX 5850 308$ (XFX version)
CPU: i5 750 http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115215&cm_re=i5_750-_-19-115-215-_-Product
Mother board: ASUS P7P55D-E "Normal" or PRO
PRO model or normal? I don't really want to Xfire...
I'll overclock the i5 to 3.2Ghz w/ turbo - if you have any suggestion, keep that in consideration!
Memory:
1600: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231321&Tpk=G.SKILL Eco
HHD: Samsung spinpoint 1T (RAID 0 array is that bad?) =(
PSU: CORSAIR CMPSU-650TX 650W http://www.newegg.ca/Product/Produc...9005&cm_re=corsair_650-_-17-139-005-_-Product $109.99 (Before $20.00 USD Mail-In Rebate)Free Shipping*
750W (if I'm going for Xfire) http://www.newegg.ca/Product/Product.aspx?Item=N82E16817371025
Drive: SAMSUNG Black 22X http://www.newegg.ca/Product/Product.aspx?Item=N82E16827151176 35$
Any cheaper option?
Monitor: http://www.newegg.ca/Product/Product.aspx?Item=N82E16824254043 Hanns·G HH-281HPB Black 28" 3ms HDMI $339.99
HSF: http://ncix.com/products/?sku=41337&vpn=RR-B10-212P-GP&manufacture=COOLERMASTER Coolermaster Hyper 212 31$
Any +1 for that cooler?
Case: Since I’m no more going for a C/F build, I gues it’s a good idea to change of case. I have to admit I have zero knowledge about this.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119197&cm_re=HAF_922-_-11-119-197-_-Product free ship 110$
Suggestion: Antec 1200 w/ CP-850
Thank you JackNaylorPE for your rapid answer, will take your suggestions in consideration, but need to know if really it worths to get the PRO model of the mobo (stability, overclockability?).
My old router died, I need a new one.
Suggestion: http://www.google.com/products/catalog?hl=en&q=dlink+655&cid=16929312685474719279&sa=title#p
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156249
If you have any other cheaper router suggestion feel free to post, but I need VPN Virtual Private Network
Memory:
Any cheaper option?
Rather than the HAF 922 w/ the Antec 750 watter, I'd suggest the Antec 1200 w/ the CP-850. Better cooling and better PSU than any of the others. The HAF 922 is somewhat smaller and would make a good match with any of the following. Here's some choices with jonnyguru.com performance ratings in ( ) w/ newegg prices
Corsair TX-750 (8.5) $109
Corsair TX-850 (9.5) $109
Corsair HX-850 (10.0) $160
Corsair HX-620 (9.5) $129
Antec Earthwatts 650 (9.0) $89
Antec TP-750 (9.5) $124
Antec SG-850 (10.0) $269 (ouch was $209 in October)
Antec CP-850 (10.0) $139 (ouch was $109 yesterday .... look elsewhere .....mwave has for $118)
Antec SG-650 (10.0) NLA
