RAM frequency problems/ OC issues
Hey guys, hope i can get some advice here. Im running an ASUS M4A78L-M mobo, with a Athlon II 620 Quadcore CPU, clocked at 2.6ghz. My RAM is Crucial 2gb DDR2 800 PC2 6400.
Problem: in AMD overdrive, my ram frequency is only showing up at 400mhz. Its supposed to be running at 800. In my bios the fastest i can get it to run at is 533. Now there are lots of options for me to OC my cpu/ram, but my experience in setting voltages and multipliers and whatnot is limited, so i dont wanna fry anything. Any help in OC`ing my CPU, and getting my RAM issue would be much appreciated. So if anyone knows how i can fix this via AMD overdrive, or in my bios, that would rock.
Thanks.
2 answers Last reply
More about frequency problems issues
  1. I don't know much about AMD CPU's and motherboards, but here is what I think is happening:
    Overdrive is reporting correctly. It's doing the same thing CPUZ does. It is reporting a RAM frequency of 400 Mhz instead of a RAM clock of 800 Mhz.
    Remember, DDR2 RAM transfers 2 chunks of data for each bus cycle (even if AMD technically doesn't use an FSB).
    If you want to overclock, learn to use the BIOS.
    Overclocking Athlons
    http://www.tomshardware.com/reviews/phenom-overclock-athlon,2161.html
  2. That makes sense. Thanks for the info. Will also check that link out. Much appreciated.
CPUs RAM
