hi all,
i have scoured every single corner of every forum including this one and although many seem to have had a similar issue with this board, nobody seems to have a solution
Asus P6T Deluxe
Intel i7 2.66ghz
12gb Corsair DDR3 (6 x 2gb sticks)
XFX GTX285 GPU
this system is just over a year old and has hardly been used until spring this year. it is used solely for video editing. i am currently right in the middle of a big project and everything was fine until i tried to reboot the machine after a short break of an hour or two and i received a warning about reselecting a proper boot device, which i had never seen before (this much seems to be quite a common problem amongst P6T users).
further investigation in the BIOS revealed that the board is no longer seeing any of the three 1TB internal sata disks. one is the western digital, which contains the OS, and the other two contain all my project files. the optical drive is the only device listed.
i have tried out everything i can find, including stripping the machine down and rebuilding it (twice!), but i cannot get any one of the three disks to be recognised. furthermore, i'm not sure they are even spinning. but how could all three internal drives suddenly crash after a perfectly normal shutdown? i have ordered a new disk so will find out in a couple of days whether it is the disks or the board.
the only recommendation i have not managed to try is clearing the CMOS. i followed the manual's instructions to move the jumper but the date in the BIOS remains the same. i don't know how to remove the battery without forcing it.
i also got the latest BIOS using the flash utility, but still nothing. i am at my wit's end and have wasted two days on trying to solve this
please help!
thanks in advance,
simon
Asus P6T Deluxe
Intel i7 2.66ghz
XFX GTX285 GPU
please help!
thanks in advance,
simon
