Will these parts match?
PSU - Chieftec CFT-750-14CS 750W
CPU - AMD Athlon II X4 630 2.8GHz SAM3 BOX/95W ADX630WFGIBOX AMD
RAM - A-Data DDR3 PC10600 1333MHz 2GB CL9
HDD - Western Digital Caviar WD3200AAJS 320GB 7200rpm 8MB NCQ SATA 3Gb/s
MB - M4A785TD-V EVO
I think they match.
10 answers Last reply
More about will parts match
  1. That will be a good setup do you have a GPU picked out yet? Also that PSU I never heard of it before so I dont know how good it is but depending on what you are gonna be running as a GPU a Quality 550 watt PSU is more then enough to run just about any single GPU.
  2. im on a realy tight budget and i will be using the inergrated GPU at first later i am going to buy a ATI Radeon 5xxx something.How many watts would i need?
  3. DDR3 with an Athlon II?
    If DDR2 mobos/DDR2 combos are cheaper, you should go with that. You really won't notice the performance of DDR3, especially with a low-end quad such as the AthlonII.
  4. 550w should suit you once you get the graphic card.
    I would buy DD2 but the motherboard does not support it.
    Il get a high quality. 550W PSU
  6. Quote:
    He means switch to AM2+.
  7. I am thinking about the future to upgrade as i said i am on a budget and i will be upgrading in the future.
  8. Did you know AM2+ is supposed to support the 6 core?
  9. I do but i got my MB orderd already .... :S From Ireland.:S
  10. Oh! Ok then at least you will get a newer socket.
CPUs AMD
