Just thought id show you lot a latest project of mine, for a friend who wanted fancy water cooling on the cheap (if thats possible haha), anyway nearly done now, just got to install windows 8 and do some bench testing...
SPECS AS FOLLOWS.
CASE- Corsair 300R
PSU- Corsair AX750w (with modular sleeving kit)
M/B- MSI 990FX
CPU- AMD FX8120
RAM- 8gb Corsair Vengeance
GPU- MSI 560ti
HDD- 1TB WD BLACK
WATERCOOLING KIT.
2 x 120mm XSPC 50mm rads (with 2 x 140mm & 2 x 120mm fans set up in a push pull)
1 x Dual BAY res with 12v D5 pump
XSPC AMD CPU BLOCK
XSPC UNIVERSAL GPU BLOCK
3/4 OD UV BLUE HOSE
ULTRA BRIGHT UV LEDs
SO heres a few sneak peaks and the link to the full album..( its a shame but the camera makes it out to be alot of blue light, when really theres just a mellow purple haze and the UV tubing lights up well)
ALBUM LINK - http://photobucket.com/corsair300rwaterbuild
Next up will be OCing the hell out of that CPU.
SPECS AS FOLLOWS.
CASE- Corsair 300R
M/B- MSI 990FX
CPU- AMD FX8120
GPU- MSI 560ti
HDD- 1TB WD BLACK
WATERCOOLING KIT.
XSPC AMD CPU BLOCK
3/4 OD UV BLUE HOSE
