Okay, I built a full sized computer desk with the intent of watercooling and putting the computer inside the desk. I will post pictures to follow, but for now I am looking for watercooling part recommendations. I currently have the computer itself housed in a crummy case while i finish the desk. Everything in the case is air cooled atm. Main parts are ASRock z77 Extreme4, 2x 6970's, i7-3770k.
What I have so far is:
http://www.frozencpu.com/products/17221/ex-wat-224/XSPC_Chrome_Raystorm_AX360_Extreme_Intel_CPU_Water_Cooling_Kit_w_Twin_D5_w_Free_Dead-Water.html
^^ Is a XSPX kit with a 360 AX Rad and dual D5 pumps
I was going to buy another 360 AX Rad to add to this, and i am buying a vga block for my Radeon 6970's. I would like to overclock both my 6970' and my i7-3770k.
So my question is, is there a cheaper way to get the same results, is 2x AX360 rads too much for 2 6970's and a i7-3770k, and can you mix two different companies coolant?
Cost right now is $820(420 for ax combo, 240 for vga blocks, 15 for extra coolant,100 for extra rad, 45 for extra tubing)
TIA
*edit Better?
TIA
*edit Better?
