Solved
Help my first build
I'm trying to build a system for the first time and I was wondering if anyone can give me advice on if this is decent rig and if it will all work togather. and if you were me what would you do differently? as you can see I'm on a budget.
ASUS M4A77TD AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813131603
Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811147023
Rosewill Stallion Series RD500-2DB 500W ATX12V Power Supply
http://www.newegg.com/Product/Prod [...] 6817182044
GIGABYTE GV-R467ZL-1GI Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814125277
ASUS M4A77TD AM3 AMD 770 ATX AMD Motherboard - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Retail
http://www.newegg.com/Product/Prod [...] 6820231277
SAMSUNG Spinpoint F1 HD322HJ 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822152096
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD/CD Rewritable Drive
http://www.newegg.com/Product/Prod [...] 6827118030
. AMD Athlon II X2 245 Regor 2.9GHz Socket AM3 65W Dual-Core Processor Model ADX245OCGQBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103687
Tuniq TX-2 Cooling Thermal Compound
http://www.newegg.com/Product/Prod [...] 6835154003
Will these work togather?
Am I missing anything?
What would you do differently?
Is this a pretty good rig for a budget setup?
Thanx for any feed back.
11 answers Last reply Best Answer
More about help build
  1. Hey dude,
    All your links are broken, which makes it a bit hard to see what you've got. But anyway, a couple things:
    The Rosewill case MAY be okay, but the PSU isn't. The power supply is one of the most important components you'll buy; a bad choice could ruin the rest of your hardware permanently. Go for a trusted brand, like Corsair, PC Power & Cooling, Seasonic, Cooler Master, Antec, or OCZ. Look for reviews of specific power supplies at sites like hardocp.com and jonnyguru.com; they're generally very good.
    What's the rig for? Gaming? If so, a better video card may be in order, even if it's more expensive. Maybe a Radeon 5750 for $130? That's your call, obviously. What's your budget?
    CPU? :)
    Finally, I'd get a bigger hard drive...it's up to you, but disk space is pretty cheap. $20 more could get you a 500 GB WD Caviar Black, and a 1 TB drive is only about $90-$100. Again, depends on how much you can spend; if you can only spare $50 for a drive, your choice seems fine.
    HTH,
    -Will
    Edit: Can't believe I forgot about Antec in the PSU list!
  2. Hi.
    1- What is your budget?
    2- The rig, Is for gaming? video edition? surf the web?
    3- You forgot the CPU
    4- The PSU isn't good, get a 500W PSU from a good brand like Coolermaster, Thermaltake, Corsair, PC power and cooling, Antec or OCZ.
    5- The GPU is old, get a 5770 or better.
    6- You post thermal compound, but, where is the CPU cooler? the stock cooler already have the thermal compound.
    7- If the RAM have a CL>8 forget it, get another with CL7 or CL8
    8- I would change the mobo for a Croshair III, 790FX-GD70 or Asus M4A79T Deluxe.
    Cheers!
  3. gaming. my budget is $400-500 I just need something to get by and upgrade later on.
  4. can I use ATX 12v on the 770 mobo or do I have to use atx psu?
  5. Best answer
    Uhmmm the budget is a problem.
    CPU 98.99 Here
    MOBO 84.99Here
    RAM 108.99 Here
    GPU 134.99 Here
    HDD 54.99 Here
    PSU 99.99 Here
    CASE 99.99 Here
  6. Best answer selected by sphinxx187.
  7. hi,
    thanx for info on the mobo. I put this together and was wondering if it will work together? I down graded a little from yours because of budget.
    is there something u wouldn't do on here?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
    Sunbeam Freezing-Storm IC-FS-BK Black Steel ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811166038
    SPARKLE SXT2401024S3-NM GeForce GT 240 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814187096
    A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333G (PC3 10666) Desktop Memory
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820211410
    AMD Athlon II X2 240 Regor 2.8GHz 2 x 1MB L2 Cache Socket AM3 65W Dual-Core Processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103688
    ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
    OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
    SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
  8. ^Good rig for now, in the future you can change the processor for an Athlon X4 or a Phenom.
    Also, change the GPU for one of THIS are better brand that the sparkle and the price is very similar.
  9. thanx for reply. I made some changes,
    ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard - Retail
    Xtreme Design w/ CrossFireX, DDR3 1800
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
    I looked up crossfirex and hyper cfx and I am confused can you explain the difference between the two? is it better to have a hyper cfx or just crossfirex? and I chose ati because of this.
    thanx dude
  10. ^That is a better mobo, BUT the RAM have a CL 9, the CL recomended is CL7 or CL8. Try to get the ripjaws series with CL7 or CL8.
    In what page you see the Crossfirex and hyper CFX?
  11. I just googled it
New Build Systems Product
