Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Help building gaming pc
Forum Systems : New Build Help building gaming pc
hi everyone,
im new here but not on the computer business, however, like everybody else im posting bcus i need some help and think this great community will help me on it :D
here's the deal:
as the topic says im building a gaming pc. i've made some research here and some other forums about building a gaming pc and so far this are the 2 girls ive on sight(w/o sound card, monitor, and a few more stuffs)this is just the basic
1 INTEL:
-GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard...$124.99(1x)
-Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor...$167.99(1x)
-Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit...$49.99(2x)
-ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler...$53.99(1x) or ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler...$36.99(1x)
-CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC...$119.99(1x)
-Antec Nine Hundred Black Steel ATX Mid Tower Computer Case...$109.99(1x)
-SAPPHIRE 100253HDMI Radeon HD 4650 512MB 128-bit GDDR2 PCI Express 2.0 x16...$64.99(2x)
-TOTAL ~ $789.91
2 AMD:
-ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard...$139.99 or MSI 790FX-GD70 AM3 AMD 790FX ATX AMD Motherboard...$167.99
-AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX...$165.99(1x)
-G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)...$84.99(2x)
-TOTAL ~ $872.91
the monitor will be the same one for both systems as well as the sound card
as u could see on AMD i still dont know to which mobo should i go with :(
the cpu cooler is not a big deal for me(i can afford both of them)
and my other issue is with the video card selection, both systems are for CFX(CrossFireX) and gaming(of course) but its kinda hard to choose a video card as ther a looooooooot of them out there with excellent results doing CFX wich gets me more confused :??:
one more thing that i would like to know if that i should go with SLI or CFX, which is cheaper and gets the best results.....btw im talking bout ~$900 maybe less budget
any help will be well appreciated....thanks to any1
EDIT: sorry bout that, one more thing im thinking maybe on water cooling as well....what would u say???
Message edited by lesterdj on 02-03-2010 at 07:01:35 AM
Reply to lesterdj
You shouldn't build the Intel system. The LGA775 socket is a dead socket. You won't see anything new for it.
Watercooling is pointless. You can get quieter, cooler solutions using air. It'll also destroy your budget.
Crossfire isn't something you do when you first build the system. It's an upgrade option.
Do you not need a hard drive or an optical? What about an OS?
Given $900, here's what I would build (assuming you need nothing but the pieces you've listed):
CPU: Phenom II X4 955 $166
Mobo/PSU: Asus M4A79XTD EVO and OCZ ModXStream 700W 80+ Certified Combo for $156 after rebates
RAM: G.Skill Ripjaws 2x2 GB 1600 mhz CAS Latency 7 $115
Cooler: Coolermaster Hyper 212 $30. Cheap and one of the best.
Case: HAF 922 $110. Bigger than the Antec.
GPU: HD 5850 $290
Total: $866.
This would be a great gaming machine, and certainly would destroy either of the above.
Message edited by MadAdmiral on 02-03-2010 at 03:37:27 PM
------------------------------ How to Ask for New Build Advice
Troubleshooting
Reply to MadAdmiral
thanks a lot madadmiral....i have another question, ive a friend wich is running this
Intel Core i7 920, Gigabyte GA-EX58-UD3R, 6GB(3x2GB)GSkill 1333 sdram with a coolermaster V8 and a poor 1gb GeForce 9500 gt, but it looks like the mobo is not recognizing 2 of the 3 rams, he has done everythng to it and nothing works so i think the 2 slots are dead so his planning on changing the mobo...he should also change the PSU and the video card in order to get a good gaming pc? is there anyway to fix those ram slots?
thanks again to everyone
Reply to lesterdj
Has he rotated the RAM sticks? In other words, did he take the working stick and put it into the other slots. Or try booting from each of the sticks in the same slot? I would download MemTest86+ and run it over night to test the RAM.
I doubt it's the board's fault. It's more likely that the RAM is bad. However, if the board is bad, there is no way to fix it.
If you're asking about what he should upgrade, that GPU has to go. It's basically an ancient card. As far as the PSU, I have no idea because you didn't list it.
Troubleshooting
Reply to MadAdmiral
the ram sticks work perfect all of them but it just boot from the first one and also nor everest and the system info recognize all of them(just 1) we rotate them we tried'em on another pc and they work so...
well sorry bout the PSU but ive never seen that PSU not even in newegg so i just dont have idea where did he buy it from or the brand and bout the GPU i told him to go with some good ATi cards(2) and go with CFX....btw should he change his CPU cooler as well while getting CFX or that V8 will be good for that purpose?
Reply to lesterdj
The V8 should be fine.
If the PSU isn't listed on Newegg, I highly doubt it's a quality unit. If he can afford it, he should think about getting a quality one. I'd stick to Corsair, OCZ, Antec Earthwatts, FSP or SeaSonic to ensure quality. Make sure it is at least 80 Plus Certified or higher.
I also wouldn't get 2 ATI cards. Buy the most expensive 5xxx series card you can afford, starting at the HD 5770 for $155. Crossfire is meant to be a cheap potential upgrade option, not a starting option.
Troubleshooting
Reply to MadAdmiral
oooo another question will i get the same results with a good air cooling system than with a water cooling one? which set up will u recommend?
Reply to lesterdj
Air by far. Water cooling can be a lot louder and doesn't typically get you any cooler. In addition, there is always the chance to spring a leak and lose the entire build.
Troubleshooting
Reply to MadAdmiral
i told him to go with the Corsair CMPSU-750TX 750W which is SLI and CFX ready and 80 Plus Certified and its cheap as well and bout the card well that is all up to him if he wants to play bad**s games but the 5xxx series are good ones.
Reply to lesterdj
oo good news..he's here reading everything lol :D....hi madadmiral lol, hey i wanted to ask u bout the mobo im planning to get, i got the ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX or ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX the prices are almost the same but it seems that the Deluxe has more potential and also better reviews than the Premium one...whachu say?
Reply to lesterdj
First, don't trust user reviews. Most of the authors shouldn't be allowed near any piece of technology.
Second, the Premium is a better choice. The main differences is that the Premium has USB 3/SATA III support, making it more future proof, while the Deluxe has an extra PCIe 2.0 slot. The problem with having 3 PCIe slots is that Crossfire only scales well up to two cards. Anything above that doesn't give very good performance gains and is a waste of money. Thus, boards that have 3 PCIe slots are a waste of the premium paid to get that third slot.
Troubleshooting
Reply to MadAdmiral
good cuz actually idk what do i want 3 PCIe anyway(im just planning to get 2 cardso_0) thanks a lot madadmiral
Reply to lesterdj
There are 1880 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 1 hour ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
