Cd rom problem
Last response: in Components
are you sure you connected it? Is it detected in the bios?
Is the cable on correctly?
Open the tray and see if you can see that the lens is still there?
I've seen them fall off on some drives.
Edit - And if your is one that has a "Play" button on the front, pop in a music cd and see if it will play that.
excuse my noobness but how do i check if it is detected in the bios?
im pretty sure the cable are in correctly
no matter what kind of cd it is nothing happens it won't even show up in my computer
anything else it could be?
Related ressources
When it fires up go in to the bios and disable quick boot. F1o and save changes. When it reboots pay close attention and see if it detects the rom drive. If it goes to quick you can stop the screen by pressing the pause button on your keyboard. If it is not listed and you already tried a diffrent molex plug an ide or sata ribbon chances are that it is bad. And I can tell you to not even bother trying to fix it they are so cheap you are better of ordering a new one instead of googling ways to repair it. Good luck
when it boots up after applying the changes a screen comes up after the bios screen which says
marvell 88se61xx adapter
adapter 1
disks information
no hard disk is detected!
does this mean it cant detect my hardrive? the computer works fine only for the cd rom so i don't understand this
Ide or atapi 0 drive 0 (or master)
What motherboard do you have?
Bios looks something like this: http://media.photobucket.com/image/boot%20drive%20detec...
Boot looks like this:
http://www.bahj.com/wisp/instructions/screenshots/booti...
Ignore the circled f11 thing... you should see your drive listed in the ide section. If its not listed there then the mobo doesn't see it and therefor windows never will. I only show the IDE because I dont think there are any sata cd rom drives.
If its not listed there, then we may have to "Turn on" the ide interface which varies depending on your motherboard.
the drive is not listed in the bios. my mobo is the ASUS m4a79xtd evo
Ide or atapi 0 drive 0 (or master)- sorry i dont understand what your asking here could you clarify
thanks
Ask the community
