Motherboard battery output test
Related ressources
saint19 said:
Remove the battery and connect the multimeter the pinouts isn't important since u only get a - when u connect the positive to the negative of the battery.
thank you,
there are 7 pins. if there is just a ground and power pin what are the other 5 for?
saint19 said:
Doest that pins have a specific color? I think that u can look in the mobo's manual to know which are the corrects for test it.
no colors. its a dell inspiron 2650 laptop
Motherboard Master
The problem is that simply measuring the voltage will not tell you much. I mean, if you charge the battery and you cannot read the full voltage across it, it is almost certainly bad. But without putting a load on the battery, measuring the full output voltage won't tell you much.
The output voltage will be something less than 20 volts. The input impedance of your typical DMM is 11 Megohms. You will pull something like 1.5 microamps out fo the battery when you try to measure. The battery can be all but graveyard dead and it will still report the full voltage.
thanks,
i want to test voltage coming from motherboard not battery.
i
Ask the community
