corvetteguy1994 Distinguished Oct 5, 2012 537 1 19,115 Oct 17, 2012 #1 hello, i just got this motherboard and a 2500k and when i try to overclock manually cpu id says 3.8ghz while prime is running but without it windows just says 3.30ghz how do i get it to stay at a constant clock. plz be specific.
Solution amuffin Oct 17, 2012 Follow this: http://www.tomshardware.com/forum/274821-29-sandy-bridge-series-overclocking-cores-guide
amuffin Illustrious Jul 29, 2011 14,977 1 41,960 Oct 17, 2012 #2 Windows doesn't report overclocked speeds on SB chips. Why would you even want a constant clock? Just have it clock up when you use stressful programs. Upvote 0 Downvote
corvetteguy1994 Distinguished Oct 5, 2012 537 1 19,115 Oct 17, 2012 #3 amuffin : Windows doesn't report overclocked speeds on SB chips. Why would you even want a constant clock? Just have it clock up when you use stressful programs. it only reports it as an extra boost to the turbo boost @ 4.2ghz Upvote 0 Downvote
amuffin Illustrious Jul 29, 2011 14,977 1 41,960 Oct 17, 2012 Solution #4 Follow this: http://www.tomshardware.com/forum/274821-29-sandy-bridge-series-overclocking-cores-guide Upvote 0 Downvote Solution
corvetteguy1994 Distinguished Oct 5, 2012 537 1 19,115 Nov 2, 2012 #5 Best answer selected by corvetteguy1994. Upvote 0 Downvote
