Extra Case Fan Upgrade: Maximum 120MM Case Cooling Fans for your selected case
Dont know the brand sorry
Primary Fan: XtremeGear Ultra Triple Heatpipes Cool Copper Heatsink CPU Cooling Fan (Extreme Silent at 20dBA & Overclock Proof)
Dimensions (L x W x H) 97mm x 77mm x 124mm
Weight 360g
Bearing Type Hydraumatic
Rated Voltage 12 VDC
Rated Current 0.13 Amp (MAX.)
Air Flow 40.3CFM
Noise 20.8 db+-10%
Speed 2,200 RPM +- 10%
Life 30,000 hours
Thermal Resistance 0.18 (�C/W)
CPU Compatibility Intel LGA775: Core2 Duo/ Celeron/ Pentium4/ Pentium D
AMD: AM2/ 754 / 939 / 940
Weight 360g
Air Flow 40.3CFM
Noise 20.8 db+-10%
Life 30,000 hours
