Solved
Whats better for gaming memory clock speed or GPU clock speed
Hello
For gamong on a graphics card whats better to have high GPU clock speed or hi memory clock speed
10 answers Last reply Best Answer
More about whats gaming memory clock speed clock speed
  1. you want a faster GPU processor speed than memory but, you can also oc them if it is too slow
  2. They are both important. You will need to explain in more detail what you are asking or the answers will be meaningless.
  3. When looking at two cards one card will have a gpu of 585Mhz and memory clock speeds of 1890 Mhz. But another card will have 850 gpu clock speed but only 1200Mhz memrory clock speed which will be the best card
  4. It depends much more on what card it is than the frequency of the core or memory. Tell us what specific cards you are looking at.
  5. The HD 5770 or the GT240
  6. The HD5770 is much better. Approximately twice as powerful.
  7. Best answer
    The 5770 is a much better card.
    Please don't double post the same question though.
    http://www.tomshardware.co.uk/forum/279905-15-whats-better
  8. Jason H said:
    Hello
    You can't compare GPUs on only core clock and memory. Most GPU models have different architectures so only a side by side benchmark will show you which card is better. That is why when comparing cards you should read reviews by popular sites: Guru3D, AnandTech, Techpowerup, etc.
    It is very simple, just do a google search: '<name of card here> Review'
  9. Thanx all for your help i certainly can make the right choice now :)
Graphics Cards GPUs Memory Gaming Graphics
