Hi
Yesterday while I was in work my brother was on my pc. He said he knocked over a glass of water but none got into the pc. He said he knocked off the power straight away.
When I came home I opened up the pc and couldn't see any water. There was a strange smell coming from it though. I turned it on and it worked and I was able to log in. But the Internet wasn't working.
I thought this might be because I had unplugged everything and put them back so I restarted the pc.The pc just kept restarting and nothing was coming up on the monitor. It didn't even show the bios screen.
I opened it up again to have a proper look and I unplugged the 12v connection. There was a tiny amount of water on it. Then I noticed something on my motherboard had blown. It's one of those small black squares.Some brown fluid seems to have leaked from it too.
The case is an Antec 300 so obviously the water got through the top fan.
Is my motherboard ruined or can it be fixed?
Could I RMA it? How would they know if it's water damage or not? I'm not even 100% sure it's water damage? How do I tell?
Thanks.
Thanks.
