Advice on New Complete System - Approximately 2,000
Last response: in Systems
APPROXIMATE PURCHASE DATE: Will be purchasing with tax return, most likely next month (March 2010)
BUDGET RANGE: Approximately $2,000 before rebates give or take depending on tax
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: (Gaming – everything else rates below gaming follows)
PARTS NOT REQUIRED: All parts required, building complete new system.
PREFERRED WEBSITE(S) FOR PARTS: newegg.com – other reputable website. Country of Origin - USA
PARTS PREFERENCES: Looking to use an AMD Phenom II X4 955 processor with a Gigabyte GA-790XTA-UD4 Motherboard. More info in the body of the post.
OVERCLOCKING: Maybe SLI OR CROSSFIRE: Yes – most likely in a year if needed.
MONITOR RESOLUTION: Decent widescreen monitor, am looking at a 23” details posted in body.
ADDITIONAL COMMENTS: A quiet computer would be nice, but I am more interested in performance. I don’t want it sounding like a jet or anything though :) .
Details below in the format Item – Description - Price
CPU Phenom II X4 955 $170
MOBO Gigabyte GA-790XTA-UD4 $140
RAM G.SKILL ECO Series 4GB (2 x 2GB) DDR3 1600 $120
HDD x2 Samsung Spinpoint F3 500 GB $110
GPU SAPPHIRE 100281SR HD 5870 $410
CPU Fan Hyper 212 + $38 (will work with AMD right?)
Power Sup. Antec TPQ-850 850W Continuous Power ATX12V / EPS12V - $156
CASE HAF 922 $130
DVD RW LG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW $29
Sound Card None, will use on-board sound.
OS Windows 7 Pro. 64 bit $140
Monitor ASUS VW266H Black 25.5" 2ms(GTG) HDMI Widescreen LCD Monitor $284
Backup UPS Help - One that is beefy enough to handle the system ?
Keyboard Razer Arctosa $53
Mouse Razer Naga $87
Mousepad Razer Vespula $40
I am looking to get a gaming PC with the money I receive from my tax return this year. This PC will be built from the ground up, so I will need everything. The tax return should be approximately $2,000.00.
The prices include shipping. Do I have everything I need for a complete system? Is everything compatible? Changes/Suggestions?
Thanks in advance.
Like was mentioned above, there is no need for the sound card. The on-board sound works just fine for 95% of home users.
I would go with the HAF 922 instead. It's very close to the same size and considerably cheaper.
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case - Retail $109.98
You're overpaying for Windows 7 if you're paying $200. You can get it from Newegg for $140.
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM $139.99
In fact, there's even a combo deal for 64-bit Windows 7 Pro + a Sapphire 5870 that saves another $20.
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
A quality 750W PSU would power your system even if you add another 5870 in Crossfire. If you want a little extra headroom you could step up to an 850W unit for a little more.
Antec TruePower New TP-750 Blue 750W 80 PLUS BRONZE Certified Active PFC Power Supply $129.99
or
Antec TPQ-850 850W 80 PLUS BRONZE Certified Modular Active PFC Power Supply $149.99
I would consider an i5 or i7 build since you have plenty of budget for one.
Thank you for your responses. I have edited the original post. I took out the sound card, added the 850W power supply, and changed the monitor and case per your suggestions. With the updated prices this will leave me approximately $100.00 for a backup UPS.
I went with the 850W power supply because I will be adding more hard drive storage, crossfire, and upgrading the processor at some point down the road.
The reason that I have not went with the i5 or i7 build is that per my understanding, this build will be more upgradable in the future.
Thanks again.
Ask the community
