I am wanting to use this as the case for my system and I need some help with the cooling layout.
ATX mother board stand in.
I have two ways, that I see, to mount the motherboard.
Fans, its between:
A- 1 200-250mm exhaust on top and 2 120 mm intake fans on each side.
B- Clear all the plastic out of there and put a 200-250 mm exhaust on each side, passive intake (not possible with option 3 above.)
Or
C- Tape up the upper vent on the side and 1 200-250 exhaust on the top.
Which combination would be better for cooling, and also where should I mount the PSU?
Fans, its between:
Or
