Hi guys, here are the components I put together last night.
CPU: i5 750 Lynnfield
Mobo: ASUS P7P55D EVO
RAM: Gskill Rip Jaws
GPU: Sapphire Radeon HD 5850
PSU: Corsair HX650w
Case: CM Storm Scout
HSF: CM Hyper 212
Monitor: Samsung 2494SW
HDD: Samsung Spinpoint F3 1TB
Optical: Lite-on DVD RW
So I put my parts together (this is my first ever build), followed all the instructions, including the step by step sticky on this board. I power up, and all the fans spin, the led lights on the board light up, and none stay lit (a good thing since staying lit would mean a problem in that specific area of the mobo), but the monitor is blank. I power down, reseat the GPU, double check on all the cable connections, power up again, same thing. The fans spin, lights work, but nothing on the monitor screen. Any idea's? It was 2AM after my last try, so I went to bed, figuring I'll give it another try after work today.
I'm going to try my other monitor when I get home, or maybe an HDMI to a small TV I have, just to see if it's the monitor. I don't think it is though, cuz the little box floats on the monitors screen, that says "analog or digital" something. Should I try one stick of RAM to see if it's a bad unit, or would it work just the same if one was faulty, but both seated?
Thanks in advance.
PSU: Corsair HX650w
HSF: CM Hyper 212
Thanks in advance.
