hi guys
every time i play any games, after about 10 minutes my pc restarts. i have asus ati 4890 and amd phenom II 955.these are the temperature stats of my graphics card ( according to ati catalyst)
idle 69 degree celcius
load 92 and above (and then pc restarts)
then i experimented by keeping the side panel of my case open . there was a dramatic decrease in temp.
idle 62 degree celcius
load 82 degee celcius
and this time temp remained stable at abt 82 and my pc didnt restart even after half an hour.
i have a zebronics reaper case. the fan arrangement in it are:
1)120 mm side fan blowing air inside
2)80 mm side fan blowing air outside
3)80 mm exhaust fan at top
the side panel i removed had the first 2 fans. . .the case has slots for two more 120 mm fans in the front and at back.wat is my exact problem and wat should i do to rectify it.is my air circulation wrong .should i install any additional fans . any help will be highly appeciable.
p.s:the temp raise even if i left the ceiling fan in my room off and if the pc runs throughout the night with the ceiling an off, the next morning i find that it has restarted.also i havent done any overclocking. . i donot get any kind of flickering in games at any point even when the temp is at 95 . .and my pc is only abt 7 months old
this is how my case looks
