Closed
Hybrid Storage Solution
  • NAS / RAID
  • SSD
  • Hard Drives
  • Storage
Last response: in Storage
February 7, 2012 8:23:08 AM
Okay so at the insistence of the people here I plan on getting an SSD, which is the Corsair 40gb F40. I plan on turning that into that Hybrid drive thing with the Intel smart response. My HDD drive of choice is the WD Black 2tb 7900 rpm 64mb cache. My question is this. Does my hdd of choice affect performance or will a 2tb green work just as well cause of the ssd? BTW how long will the SSD last, cause I read somewhere that since I'll be using it for caching it might not last that long.
More about : hybrid storage solution
Best solution
a c 545 G Storage
February 8, 2012 2:13:30 AM
The WD Black may benchmark slightly better than the WD Green but you will not notice any real-world difference between the 2 drives when using Intel SRT.
BTW how long will the SSD last, cause I read somewhere that since I'll be using it for caching it might not last that long. said:
Not true. Don't worry about drive longevity. You will upgrade the drive or it will fail for other reasons long before it runs out of P/E cycles.
February 8, 2012 9:16:13 AM
Best answer selected by Freshbuilder.
Score
February 8, 2012 5:29:23 PM
This topic has been closed by Mousemonkey
Score
