Help With First Build
Last response: in Systems
Hi, I am planning my first homebuilt computer and was wondering if all these parts are compatible. The parts are:
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - Retail
AMD Athlon II X3 435 Rana 2.9GHz Socket AM3 95W Triple-Core Processor Model ADX435WFGIBOX - Retail
SAPPHIRE 100284L Radeon HD 5750 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Retail
COOLER MASTER Elite RC-310-BWN1-GP Black Steel / Plastic ATX Mid Tower Computer Case - Retail
Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
APEVIA CF12SL-UBL 120mm Blue LED Case Fan - Retail
ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen LCD Monitor - Retail
Microsoft Comfort Curve Value Pack - OEM
Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply - Retail
The system will be used for music, homework, and lots of gaming. I would like to play games like WoW, Crysis, and Unreal Tournament. Would this get the job done?
Also, would using HDMI for a monitor make a big difference for picture quality? Thanks.
More about : build
Looks good. (wow I can't believe the RAM costs more than either the motherboard or the processor, I got so used to $150 motherboards and $20 RAM.)
Gaming performance will be good, it should run Crysis well on medium to medium/high settings.
DVI and HDMI are exactly the same thing, except that HDMI also carries the audio inside the cable. There's no difference in the picture.
The 5750 is a very light card for your resolution. You will be able to play games at lower details, but you certainly won't be cranking up the eye candy in Crysis. You would want at least a 5850 to get a good gaming experience at your resolution. Here's a combo deal that would be great if you can stretch the budget a bit:
Windows 7 Home Premium 64-bit + Sapphire 5850 combo
You can get a faster HD for less money.
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive $49.99
Related ressources
Depends on the GPU, and if you want to Crossfire later.
Antec is pretty good, but most people tend to recommend the Earthwatts models. Also, note that the bigger OCZ I listed is cheaper after rebate. Or this 700W one is the same price. Both of these are good quality units.
Ask the community
