Sata drive problem
I have this problem where my system will not boot as hard drive is missing. i have on numerous times changed the sata cable to different sata slot on motherboard and then my system boots with no problem untill a day later i try to boot again and the hard drive has gone which again i have to change sata cable slot on the board again. anyone help and advise what maybe the fault here thanks
2 answers Last reply
More about sata drive problem
  1. Have you tried another SATA data cable? Maybe the one you are using is damaged.
  2. yes have tried new sata cable also same problem
Motherboards SATA Boot Hard Drives Cable
