Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > [Solved] HELP picking a 500gb hard drive
Forum Storage : Hard Drives [Solved] HELP picking a 500gb hard drive
Best answer from anort3.
If you have a SATA 6.0 Gb connection, go with the WD Blue. If not, then get the green.
Reply to shavale
Best answer
Having SATA 3 ( 6Gb/s ) does not matter one bit to a mechanical hard drive since no mechanical hard drive can saturate anywhere near that bandwidth. In fact mechanical hard drives can only use SATA 2 ( 3Gb/s ) bandwidth in bursts. Only an SSD needs SATA 3.
The Hitachi is probably the fastest of the 3 since it is a performance drive. The WD blue would be second and considered a storage grade drive and the WD Green is an " Eco" drive meaning it is fine for storage but not something you want Windows on.
------------------------------ i7 2600K @ 4.5/P67A UD4/Scythe Mugen 2 Rev B/OCZ Vertex 2 120GB/2xWD 640 Blacks/Antec 1200/Samsung 23in LED LCD/EVGA GTX 460/2x4GB GSkill Ripjaws X DDR3 1600 7-8-7-24/Windows 7 Ultimate x64/Corsair 750TX
Reply to anort3
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1753 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Connecting a Laptop Hard disk directly to Desktop (SATA)
By RetiredChief, 2 hours ago:
fantastik250 - Sata interface is only for data. Does not adjust any voltages. power is...
Best offers
Top experts
