Help me choose motherboard
Okay i need help again choosing motherboard and maybe a psu
so i'm stuck on these motherboards
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128394
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131595&cm_re=asus_m4a785-m-_-13-131-595-_-Product
which one should i choose and which one has more Features they seem about the same to me so
when i say Features i mean overclocking unlocking cores fan plugs, stability and performance and goodies LOL
now for the psu
what do you think about this psu now i have 5 fans in my new case i just got and 2 or 3 cd-rom and 2 hard drives and maybe a video card don't know
what to get but for now im going be using the onboard HD 4200 it got to be better then my outboard geforce4 mx 440 on my dell LOL!!
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4558897&sku=U12-40505
just give me real answers and don't tell me bs answers like go and buy $200-300 motherboard or dell or something if you want stability and performance k. thanks chris hey by the way im using the AZZA Solano 1000 Black case
5 answers Last reply
More about help choose motherboard
  1. i would get an am3 board, or the asus if its only those two. also, get this psu all the way:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
    nice case by the way :)
  2. I'd go with ASUS every time, I'm currently using the M4A785TD-M EVO, rock solid board, way better than the Gigabyte I had before. The onboard GPU is better than most as it comes with 128Mb of Vram, DirectX 10.1/shader 4.0 support. (hey, it'll do until I can afford a decent card).
    the rest of the build is: Phenom II dual core @ 3.0 GHz, 4Gb G-Skill @ 1600, 750 Gb WD HDD, DVD burner, card reader, 520 W PSU and a nice piano black case.
    Running Win 7 64Bit. General use plus web dev and Java/VB/C# dev.
    now for the psu
  3. Antec Board
    PSU, Antec Earthwatts /Corsair VX or TX series.....Corsair HX / Antec SG series bit expensive, useful for extreme Overclocks and multiple GFX cards but way more PSU than you need for that build.
  4. what about this motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813130233 is it any better then the 2 i listed i just want a bang for the buck motherboard/CPU you know what i'm saying
  5. that mobo is great since it is 785g, supporting the 4200 hd integrated, and is am3, so it supports am3 and am3+ cpus, and ddr3 memory. it is also a good board by a good company
Homebuilt Performance Motherboards Systems Product
