Tom's Hardware > Forum > Games General > Games General Discussions > Thief Gold: What is the ideal CPU Speed?
Forum Games General : Games General Discussions - Thief Gold: What is the ideal CPU Speed?
Archived from groups: alt.games.thief-dark-project (More info?)
I just reinstalled Thief Gold (under winxp) on a fast athlon system with a
9700pro. The guards and people move too fast. Clearly there is a speed
governing problem of some sort.
On my system I can change the cpu speed from anywhere between 500mhz and
2.3ghz; What is the sweetspot for playing Thief Gold for smooth framerate
(1024x768) but no 'quickstepping' guards ? Any tips appreciated!
rms
Sponsored Links
>rms
Have you turned on the "Vertical Sync" in your graphics card settings?
Reply to Anonymous
- 0 +
I think that fixed it, thx!
rms
Reply to rms
> rms
Hey, that sounds a lot like the system I built in February: Athlon XP
3200, Radeon 9700 Pro.
I went through an OS fandango in the first couple of weeks, partly
because Windows XP (either flavor) didn't seem to want to install, and
partly because Win 2k didn't want to run certain older games.
Eventually I got the bugs worked out and XP Pro installed. Some older
games - Mechwarrior 3 in particular - still don't work right.
Which R9700Pro did you get? I went with the Powercolor edition, which
was the only one Newegg was selling at the time. I simply couldn't
stomach $400+ for a Radeon 9800 Pro, and I was mostly concerned with
running older games that made my extremely underpowered (Duron with no
3D hardware) notebook choke. Never had 3D card before - quite amazing!
What's frustrating is that a few older titles (again, MW3) simply don't
work, even though I'm running basically the same OS. Maybe I'll try
slowing down the CPU.
Objekt
Reply to Anonymous
- 0 +
Sapphire. It was $320 when I bought last year. I put a 1U cpu heatsink
on it and it oc's to stock 9800pro levels.
Dunno about this, XP does have joystick/controller issues. Do some
googling on that title, or ask on fan forums. Perhaps Dosbox (I just
looked, it doesn't) or one of the other emulator progs will help.
Anyway for ThiefGold I used "f:\setup.exe -lgntforce" to install it, and
enabled vsync. Everything works great!
rms
Reply to rms
- 0 +
heatsink
> You can OC those? My Powercolor version came with a heatsink and fan on
> it. I didn't know they were making them without - I thought the GPU
> would fry itself without a heatsink.
:) I took off the stock heatsink & replaced it with this one
http://www.directron.com/directron/dc1206bmr.html
If I was doing it now I'd use a VGA Silencer
http://store.yahoo.com/svcompucycle/vgaandbga.html
I don't think it's worth doing now tho, just sell your 9700p and get a
X800 :)
rms
Reply to rms
"Objekt" <t37student@yahoo.com> wrote in message
news:E6Mmc.94105$G_.74196@nwrddc02.gnilink.net...
> Objekt
http://www.ntcompatible.com/compatibility.html has a fairly updatet list of
what games and programs works on XP and who dont. Often you find the
solution to how to get some older games to work if they don't straight out
of the box.
Reply to Anonymous
>>Objekt
> of the box.
Unfortunately that wasn't enlightening; I have already tried running MW3
with Win95 compatibility mode, to no avail. Looks like I have to write
that one off.
However, I did stumble across a port of Duke Nukem 3D for Windows. Woohoo!
Been a LONG time since I played that.
Objekt
Reply to Anonymous
>>>Objekt
>> of the box.
>that one off.
Maybe, in fifty years or so, you'll get to play Duke Nukem 4Ever
______________________________________________
What's up Chuck?
Reply to Anonymous
There are 1270 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
