Tom's Hardware > Forum > Home Theatre > ReplayTV > Best DirecTV Tuner fo work with ReplayTV?
Forum Home Theatre : ReplayTV - Best DirecTV Tuner fo work with ReplayTV?
Archived from groups: alt.video.ptv.replaytv (More info?)
I have been to the DirecTV web site and they have manuals for nearly 10
dozen different tuners.
Which ones work the best (conversely, which ones should I avoid)?
Do any use the serial cable instead of an IR blaster? Any models work
better with addressing (because I'll have two in one room)?
Jeff
NOTE: Remove underscores from my e-mail address to reply personally.
Sponsored Links
On Mon, 18 Apr 2005 04:21:22 -0500, Jeff Lindstrom
Both my DirecTV receivers are RCA model DRD420RE. These work well and
use serial control cables (including the DE9-RJ22 adapter that comes
with the Replay).
Note that the Replay only sends the channel change command to the
receiver, never receives.
This is now an older model (although new enough to get locals on
channel numbers < 100), although newer models should work too (when
you set up the Replay, you'll get a "APG" option which you need with a
newer receiver).
You'll need a special receiver to get sat-D (the new satellite
location at 72.5 degrees, just some locals).
Mark Lloyd
has a Replay 5xxx
http://notstupid.laughingsquid.com
"The idea that there is an invisible being who
created and still runs this old universe is so
childish, so obviously contrived, that it is hard to
believe anyone with even a modicum of education can
still fall for that scam."
Reply to Anonymous
My 2 are in the same room (less than a foot apart). The 2 are
completely independant, and so there is no need for addressing.
Note that the Replay should have exclusive control of the receiver,
which is what the Replay expects. Using it's (the receiver's) control
could interfere with automatic recordings.
If you're using IR (rather than serial) control, put some
non-transparent tape areond the IR receiver on the receiver to prevent
interferance. Serial control is preferable.
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
DRD420RE works fine
and also the DRD435RH seems OK (this is the newer RCA model)
"Jeff Lindstrom" <j_r_lind@adelphia.net> wrote in message
news:Xns963C18303A853jeffsmessages@216.196.97.142...
> Jeff
Reply to Anonymous
On Thu, 21 Apr 2005 16:28:31 -0400, "Al Swearengen"
<al_swear@gemsaloon.com> wrote:
>DRD420RE works fine
The DRD420RE is what I have and it works fine with serial control.
Does the DRD435RG work with serial?
>> Jeff
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
I should have been more specific. The DRD420RE works well with SERIAL and
will work fine even with the older ReplayTVs (like the 2000 models)
The DRD435RH works fine with SERIAL with the newest ReplayTV models only
(5000 and up I think) it won't work with older ReplayTVs like the 2000
I've never tried the IR blaster on these models, avoid IR blaster if you
can...
"Mark Lloyd" <mlloyd@5xxxmail.com5xxx> wrote in message
news:cc5g61trike61q3lvdrtd3upbckq7be8s0@4ax.com...
> >DRD420RE works fine
work
> >> Jeff
> Mark Lloyd
> has a Replay 5xxx
Reply to Anonymous
> with the Replay).
Ok... it seems there are several models which will work with serial
control; I just have to make sure I get one and check it out when it is
installed.
> ... (when
> newer receiver).
APG option?
I am a bit concerned about the cost of converting to the HD boxes when
they become more widely available (those 150 nationwide HD channels and
some 1500 HD channels carrying local content).
I should get it in writing that I will not have to pay an Early
Termination fee when I upgrade and change equipment.
Jeff
Reply to Anonymous
On Fri, 22 Apr 2005 00:27:25 -0500, Jeff Lindstrom
>> with the Replay).
>installed.
>> ... (when
>> newer receiver).
> APG option?
It you have recent Replay software, you'll see this option when
setting it up to use DirecTV. When asked how to control the receiver,
you'll have 3 choices, "IR blaster", "serial", and "serial (APG)". APG
seems to mean Advanced Program Guide. These (the newer models) or
receiver require a somewhat different serial control protocol. The
Replay now supports that.
You'll need a new receiver when that happens. Perhaps similar to the
ones required for sat-D. You'd have to contact DTV for more
information on that.
Replay doesn't currently support HD (although the HD receiver should
be able to convert it to NTSC). There will be a HD model available
eventually, but it'll probable be an integrated receiver-DVR. The
hardware to make a general-purpose HD DVR is expensive (and there's
the business-controlled government "protection" that's going to get in
the way here to).
Probably, although I don't know about that. I bought my receivers
directly, and so didn't have to deal with that.
Mark Lloyd
has a Replay 5xxx
Reply to Anonymous
There are 1306 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
