Networking problem
I've some issue when I'm trying to connect notebook (IBM T40) running windows XP SP3, to a file server, the other thing I've seen that it rotates the IP from xxx.xxx.xxx.168 to 177, keeping the mayor time in the last number, it pings the server, it replies, but trying to access it says that the path is not found. Help me it's very important to solve it, I've tried reinstalling driver, installing another ethernet card.
HELP! :ouch:
4 answers Last reply
More about networking problem
  1. the ip address shouldn't be just changing by itself... can you set the servers ip address to a static address?
  2. Is it possible that your both plugged in and connected via wireless getting two IPs and making weird stuff happen?
    Disabled Wi-fi now I can see the machine from other pc, even printing, but from the machine, nope
  4. more wired :pt1cable: when I fix the IP higher than x.x.x.177 and then remove the fixed IP, it stills with the higher value :o
    Reformating will be the last option this guy has pass thru 5 computers :ouch:
LAN Networking
