Just wondering their are quieter case fans in my Antec 902 . Have stock Antec 120 mm fans. Are their quieter fans especially turn up 70 % or 100 % ? Btw, have filters on my 902. That affect fan choice ? Thanks for your advice.
the dB levels mentioned by the manufacturers are rarely correct. The best way is to read reviews as much as possible and try to make your own conclusion...
I have Noiseblockers and they're virtually silent.
What % can you turn up until it is no longer silent ? Sounds very impressive. Will having the 902's filters in front matter much ? Thanks again for the info.
