Solved
Best CPU Cooler (closed circut water or air) for FX-8320?
anort3 said:
For high end air cooling the Noctua or the Phanteks are the best.
The H100 is a bit better than either of those. It's also louder.
You want the best cooler you can get for a 5Ghz attempt.
Yes I will! But what are your thoughts on the Turniq 120 Extreme? I saw on a cooler benchmark chart that it was in 2nd or 3rd place.
Related ressources
CPUs Master
Overclocking Authority
The Tuniq is decent but not on the same level as the Noctua or Phanteks. Those 2 trade blows for first depending on who does the tests.
Notice here the Noctua compared is a older design since the Tuniq is an older cooler.
http://www.hardwaresecrets.com/article/Tuniq-Tower-120-...
Here too.
http://www.bit-tech.net/hardware/cooling/2009/12/03/tun...
This has both the new and old Noctua coolers in the chart. Even my older Scythe Mugen 2 beats the Tuniq quite easily here.
http://www.tweaktown.com/reviews/3096/tuniq_tower_120_e...
As I said above the H100 beats both of these coolers by a decent amount.
Here too.
Well with the Phanteks, whcih I think I am going to stick with, I am just barely under my budget of $1000 for my new build. Do you know the clearance WITH 200mm side fan on the Corsair 500R? I have looked everywhere but can't seem to find it.
anort3 said:
From what I see it might not fit with the side fan.
You do have low profile RAM too right? You will need it with any large air cooler.
I have G.SKILL Ares, which are only 32mm in height :)
anort3 said:
Actually it does fit. I found this.
http://www.youtube.com/watch?v=TkLeFnyqyCk
Edit:
Also you did see it come in other colors too right?
http://www.newegg.com/Product/ProductList.aspx?Submit=E...
Thanks! I did see that, but I am getting the white version 500R so might as well stick with the same color. If only the top heatsink caps were white too, not silver :(
Ask the community
