Diamond 4890 XOC is making strange noise
I recently got my Diamond 4890 XOC video card back from RMA. I happy to find that it can OC to 1000Mhz/1075Mhz and the temps stay below 80C. It makes a strange noise whenever I enter 3D applications. The sound starts the second that I click "start game" and stops the second I click "quit game". It happens the same when it's overclocked or not. It benchmarks well. I can't find where the sound is coming from, it's not coming from the fan. Does anybody have any suggestions of what the sound might be or how to test it.
It's hard to describe. It's not a whine. It's like scratching your fingernail across a table or desk, but it's a constant "pitch". I've opened the case and looked around, but I can't find where exactly it's coming from.
Related ressources
no it may take a few days to a month
if you run this card, lets say it is the power consumption, if it keeps drawing too much energy from the mobo the circuits will fry
if it the data being sent then th the data might also fry the circuits
it is a bit hard to explain......
How critical is it that I need to remove it right now? Can I leave it in for another week before I RMA, or do I need to remove it immediately?
I just lowered the clock speeds to 4870 levels (750/900Mhz). Will that help prevent problems?
Alright. I have new monitor coming on Tuesday, so I want to try it out. I'll send it back shortly after that. Thanks for your help. I'll let you know if it happens to break before I return it.
Ask the community
