The computer says new hardware found it install succesfully but when I click to view my files it displays a massage "Please insert a disk into drive G" it is a 8 gigabite Dixon flash drive. Please I need my files..
Embarrassing it is, I've got the same problem with my Kingmax 4Gb pendrive. ><
However after reasonable amount of researching I've came across a few posts stating that this problem could be solved by low level formatting it...
there are a few tools which can low level format a Flash drive, one of which is...
I suggest that you try it out... unfortunately It didn't work out for me...
the tool did not recognize my usb flash drive...
Just let me know if it works for you.....
