Hi all,
Within the next few months i am looking at building a new system.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: (Gaming)
PARTS NOT REQUIRED: All parts required/new build
PREFERRED WEBSITE(S) Scan - UK
PARTS PREFERENCES: AMD,Asus,Corsair,Antec, Western digital
OVERCLOCKING:maybe SLI OR CROSSFIRE: Yes to Crossfire
MONITOR RESOLUTION: 1920X1080
ADDITIONAL COMMENTS:
I am looking at getting a Phenom II 955 be (AM3), Asus crosshair III, 4gb DDR3 1600mhz Corsair Dominator XMS3 ( upgrade to 8gb at some point), 2 x Western digital 7200rpm 500gb, Liteon optical drive, 5.1 surround sound, 23" 1920x1080 Monitor, Antec 900, and a Asus Hd 5770 ( upgrading to 2, Crossfire later on).
Using windows 7 64bit.
Putting all this togeter with the 8gb ram and the Crossfire setup 2x hd 5770 the recommended wattage is only 365w, calculated by thermaltake power supply calculator.
This just seemed a bit low for me and wondered if this was correct and could do with a bit of help or information on this.
The psu's i have been looking at getting are the Corsair tx series and range from 450w to 950w. It mentions on some i think that they have dual 12+ rails not sure what this is.
Thanks for your help.
