Advice on New system.
Last response: in Systems
I would like ALL tips, hints, tricks and advice. I want to know if all of these parts are compatible with each other.
Motherboard:
Video Card:
Processor:
Ram:
PSU
Enough power for this build right?
Case:
Motherboard is an ATX, case says it will fit the ATX motherboard so it should fit right? Power Supply is normal size so the PSU should fit right?
Hard Drive:
Windows:
Home Premium instead of Professional?
So only thing I'm really missing is a CD Drive and Bluetooth, yes I want both. Any idea on what bluetooth that is a good price/compatible?
Another thing about building this computer is that I have NO CLUE about Bios and afraid i might mess something up with that...and tips on this mobo and the bios or another mobo that is good with this system configuration and that is easy Bios?
Thanks in advance guys!!!
More about : advice system
This is a better PSU and comparable case for a cheaper price:
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
Pick a heatsink from the top 3 here:
http://www.silentpcreview.com/Recommended_Heatsinks
http://www.frostytech.com/top5heatsinks.cfm#INTELHEATSI...
http://benchmarkreviews.com/index.php?option=com_conten...
pick a TIM from the top few here:
http://www.hwreviewlabs.com/index.php?option=com_conten...
http://www.xbitlabs.com/articles/coolers/display/therma...
MoBo - Check whether this MoBo can not use twin video cards at x 16 x 16 ..... newgg spec say only x16/x8/x4/x8 .... Think about whether you ant USB 3 and SATA III as in ASUS P6X58D Premium
Memory - consider whether DDR1600 CAS 5 ($229) or 7 ($179) fits your budget.
Ok so I'm going with the PSU and Case combo that you suggested and the motherboard you suggested.
Case, PSU Combo
Motherboard
I want this CPU cooler
But I'm THINKING of holding off to see if I even need to use it? Or are you saying that it's a fact I'm going to need to use it? Even if I DO use it Will it fit in my case? That cooler looks like a biggie and wondering it will fit (even though my case is a biggie too.)
I'm also changing my hard drive from my original http://www.newegg.com/Product/Product.aspx?Item=N82E168... To http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Now I got another question.... The Motherboard has a SATA 6gb/s and the Hard drive is 3gb/s does that matter compatible wise? I know that might be a dumb question but I wanted to ask it. Or does that mean since the hard drive is only 3gb/s the 3gb/s extra from the motherboard just won't be used....?
I also decided with this ram for the new parts.
any question on the ram choice?
Thanks A LOT for responding and helping me.
Ask the community
