What Power Supply for this system?
I've been having troubles choosing a power supply for my system here are the specs
CPU: Intel Core i7 930
Motherboard: EVGA X58 SLI LE
HDD: Western Digital Velociraptor 450GB
RAM: OCZ 6GB i7 Edition 1600
GPU: XFX ATI Radeon HD5850 Black Edition
ODD: SATA Sony 22x DVDRW
PSU: ???
Case: Antec Nine Hunderd Two 902 Mid-Tower Case
Cooler: Noctua U12P-SE2
Upgrades
Another Velociraptor in RAID 0
Another HD5850
another Set of RAM
will upgrade cooler
I'm was thinking about getting a Antec True-Power Quattro 850 because its Modular but i can't seem to find any other power supplies cheaper than it. Any suggestions?
5 answers Last reply
More about what power supply system
  1. Would a 750W be enough for the future? i calculated on the Extreme Power Supply Calculator and it came up with 538W
  2. Its more than enough but I tend to get more than I need in a power supply:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&cm_re=corsair_power_supply-_-17-139-006-_-Product
    Id be willing to bet that corsairs 650 watter would be plenty as well. Its more like a 750 watt power supply compared to most other brands...
  3. A pair of 5850's needs about 18 - 20 amps. The CPU will need about 10 - 12 amps.
    A good 650 watt PSU would do, but it may not have all the PCIe power connectors you need.
    A Corsair 750TX (60 amp 12 volt rail)
    would be plenty.
    Review:
    http://www.hardwaresecrets.com/article/505
    I'm with englandr. I also tend to overspec PSU's. I try to operate them at 50% - 70% of rated capacity.
  4. i was looking for a modular. e HX750 was more expensive than a True-Power Quattro 850. What about that 1?
  5. Yeah the Quattro is good not top notch but good maybe you might ant to look at the XFX PSUs.
    edit: I was wrong the Quattro is top of the line in quality:
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=58
Power Supplies Components Product
